Ansys Learning Forum Forums Installation and Licensing Ansys Products Lifting Analysis of a machine Reply To: Lifting Analysis of a machine
mohan.urs
Hey,
The error suggests that there is some body which is going through rigid body motion or some contact is missing or not set up properly. I would suggest you to check initial contact information and also double check your setup. If you need more help on that you can post some snipshots which would help the forum members to check your setup.
Also check out this course to understand more https://innovationspace.ansys.com/courses/courses/prevent-rigid-body-motion-in-contact/
Mohan Urs
