Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Solution Inititalization › Reply To: Solution Inititalization
November 12, 2024 at 12:07 pm
Odd, the hybrid scheme shouldn't take too long to run and then pass to solve. Can you open the transcript and see what's going on?Â
Just an aside, should the gas density vary with temperature as buoyancy may be significant in low flow HVAC domains.Â
