Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › When CSF is introduced using DEM-SPH, particles are popped. › Reply To: When CSF is introduced using DEM-SPH, particles are popped.
November 12, 2024 at 12:01 pm
Hello Hiroki,
What is the size ratio between DEM and SPH? Try adding complexity little by little. Start with SPH-only and see if it is stable.Â
- If you are simulating WCSPH, check density clip.
- If you are simulating IISPH, check pressure convergence.
- Also check geometry triangles, if skewed. Inappropriate triangle distribution or size would led to this problems.
Check DEM-only too. If the Young Modulus is too low it could be a problem.
Best regards,
Lucas
