Ansys Learning Forum Forums Installation and Licensing Ansys Products Tutorial or Help for 2 way FSI Reply To: Tutorial or Help for 2 way FSI
ashishkumar.gupta
Hi Paul, any update on the issue? I am still stuck on the same issue.
Most of the FSI tutorials show the effect of Fluid on Solid. I have not found something in which Mech. body movements causes fluid to move. In my cases, fluid is present between ball and race and 0.1 mm fluid is not able to transfer the forces from IR to ball. If I make 0.1 um or 0.01 um fluid film, it is another issue with meshing and all....
…So it is quite confusing to implement this idea in Ansys even though I know the physics behind it.
Please do let me knoe if youi need more information or pictures from my side? Thank you.
