Ansys Learning Forum Forums Discuss Simulation Fluids Atomization through collision Reply To: Atomization through collision
It should work. But both streams must be the same DPM material. The size and force effects can come from DPM collision or flow field. But check how the model works too: there are some assumptions that can make the effect somewhat mesh dependent.Â
