Ansys Learning Forum › Forums › Discuss Simulation › Embedded Software › Understanding causality errors when using `pre` and `last` in a Scade program. › Reply To: Understanding causality errors when using `pre` and `last` in a Scade program.
November 12, 2024 at 9:49 am
Actually, in your model, the activate block compute the output y. But activation of the activate block also depends on the variable y. This leads to a causality error.
If you want to resolve this error, you should add a delay. Example:
type T = enum {a, b, c};node WhenBlkSample(x: T) returns (y: T last = b)let activate when last 'y match | a: y = a -> pre(y); | b: y = x; | c: -- empty returns ..;tel
