Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › What is the difference between SECFORC and SPCFORC? › Reply To: What is the difference between SECFORC and SPCFORC?
mohan.urs
Hey,
The SECFORC outputs the forces at a cross section whereas SPCFORC outputs the forces which are associated with BOUNDARY_SPC command.
Check out this FAQ which talks about various force analysis Force Analysis — Welcome to the LS-DYNA support site.
Since this a is uniaxial tension test it should have one fixed support and a displacement or force at the other end so SPCFORC should do the trick. But i would suggest you to go through some literature to make the best choice since you have to match the values to that of the experimental.
Mohan Urs
