Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Help: Setting of mooring lines › Reply To: Help: Setting of mooring lines
nguyenthithanhdiep1994
Thank you so much for your response. I solved this problem. However, I have another problem with the yaw motion response in the time domain. I simulated only the case of wave direction of 180 degrees. However, the ship rotated continuously 1 unreasonable when the wave direction was 180 degrees as shown in the picture below. Theoretically, when the ship operates 180 degrees, yaw motion is almost non-existent. Is there has any way to reduce the yaw motion such as adding the torsional stiffness or something?
