Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Exporting Particle History Data › Reply To: Exporting Particle History Data
nobrien
I should add that this will only export the particle landing locations; trajectories/tracks will not be exported. You could export tracks to a file using the fieldview format because it is all a text file, but you would need to write a script to go through it for your own purposes.
