Ansys Learning Forum Forums Discuss Simulation Photonics Trapezoidal ring Reply To: Trapezoidal ring
Kirill
Hello Rahul,
I can suggest following debugging tips.
Isolate the issue. Try simplifying your script by commenting out parts that could be causing the problem. Focus on the most reliable sections and make sure each one works when tested individually.
Check your waveguide parameters. If you’re having trouble with waveguide objects, double-check that the construction parameters are correct. It can help to print them out and manually create a few waveguides with those parameters to see if they behave as expected.
I’m not sure if this would be helpful, but this script creates a set of concentric waveguides with tilted walls.
for (x = 1:10) {
    addwaveguide;
    set("name", "wg_" + num2str(x));             # Set waveguide name
    set("x", 0.0); set("y", 0.0); set("z", 0.0); # Position of waveguide
    set("base width", 600.0e-9);
    set("base height", 220.0e-9);
    set("base angle", 60.0);
    # Angle and arc parameters
    start_angle = -30.0; end_angle = 30.0; radius = x*1e-6; m = 0.55191502449;
    start_angle_rad = start_angle * pi / 180; end_angle_rad = end_angle * pi / 180;
    arc_angle = end_angle_rad - start_angle_rad;
    m_adj = m * arc_angle / (pi / 2);
    # Calculating control points for Bezier curve approximation
    p0_x = cos(start_angle_rad) * radius;
    p0_y = sin(start_angle_rad) * radius;
    p1_x = p0_x - sin(start_angle_rad) * m_adj * radius;
    p1_y = p0_y + cos(start_angle_rad) * m_adj * radius;
    p3_x = cos(end_angle_rad) * radius;
    p3_y = sin(end_angle_rad) * radius;
    p2_x = p3_x + sin(end_angle_rad) * m_adj * radius;
    p2_y = p3_y - cos(end_angle_rad) * m_adj * radius;
    # Defining poles
    px = [p0_x; p1_x; p2_x; p3_x];
    py = [p0_y; p1_y; p2_y; p3_y];
    poles = [px, py];
    set("poles", poles);                     # Apply poles to the waveguide
    set("material", "Si (Silicon) - Palik"); # Set material for the waveguide
# Create a rectangle
addrect;
set("name", "rectangle");
set("x", 6.0e-6); set("x span", 12.0e-6);
set("y", 0.0e-6); set("y span", 12.0e-6);
set("z", -220.0e-9); set("z span", 220.0e-9);
Best regards,
Kirill
