Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › How to get the rotations of each node in a plate modeled through solid elements? › Reply To: How to get the rotations of each node in a plate modeled through solid elements?
/BATCH Â
/input,menust,tmp,''
WPSTYLE,,,,,,,,0
/NOPR Â Â
KEYW,PR_SET,1 Â Â
KEYW,PR_STRUC,1Â
KEYW,PR_THERM,0Â
KEYW,PR_FLUID,0Â
KEYW,PR_ELMAG,0Â
KEYW,MAGNOD,0 Â Â
KEYW,MAGEDG,0 Â Â
KEYW,MAGHFE,0 Â Â
KEYW,MAGELC,0 Â Â
KEYW,PR_MULTI,0Â
/GOÂ
/PREP7 Â
ET,1,SOLID185 Â Â
MPTEMP,,,,,,,, Â
MPTEMP,1,0 Â
MPDATA,EX,1,,1e9
MPDATA,PRXY,1,,.3 Â Â
MPTEMP,,,,,,,, Â
MPTEMP,1,0 Â
MPDATA,DENS,1,,6700Â
BLOCK,0,10,0,10,0,1,
FLST,5,8,4,ORDE,2 Â Â
FITEM,5,1 Â Â
FITEM,5,-8 Â
CM,_Y,LINE Â
LSEL, , , ,P51XÂ
CM,_Y1,LINEÂ
CMSEL,,_Y Â Â
LESIZE,_Y1, , ,10, , , , ,1Â
MSHAPE,0,3DÂ
MSHKEY,1
CM,_Y,VOLU Â
VSEL, , , , Â Â Â 1Â
CM,_Y1,VOLUÂ
CHKMSH,'VOLU' Â Â
CMSEL,S,_Y Â
VMESH,_Y1 Â Â
CMDELE,_Y Â Â
CMDELE,_Y1 Â
CMDELE,_Y2 Â
*dim,impulse,table,3
*SET,impulse(1,1),1,0 Â Â Â , Â 0 Â Â Â Â Â Â Â ! VALUES OF EXCITATION
*SET,impulse(1,0),0,22*timestup, Â 1 ! CORRESPONDING VALUES OF TIME Â
F, 177, FZ, %impulse% Â Â
WPSTYLE,,,,,,,,0
FLST,2,44,1,ORDE,12Â
FITEM,2,1 Â Â
FITEM,2,-11Â
FITEM,2,122Â
FITEM,2,143Â
FITEM,2,153Â
FITEM,2,-161
FITEM,2,243Â
FITEM,2,-244
FITEM,2,267Â
FITEM,2,-268
FITEM,2,287Â
FITEM,2,-304
/GOÂ
D,P51X,ALL, , , , , , , , , , Â Â
ANTYPE,4
TRNOPT,FULLÂ
LUMPM,0Â
FINISH Â
/SOL
NSUBST,1000,0.01,0.001 Â
OUTRES,ERASE
OUTRES,ALL,ALL Â
TIME,1 Â
SOLVE Â Â
/post1
set,last,last
*dim,node11,array,2,3,1
node11(1,1)=nx(11)
node11(2,1)=nx(11)+ux(11)
node11(1,2)=ny(11)
node11(2,2)=ny(11)+uy(11)
node11(1,3)=nz(11)
node11(2,3)=nz(11)+uz(11)
*vfun,local11,local,node11(1,1),12
faced error!
