Ansys Learning Forum Forums Discuss Simulation Optics RMS spot size interpretation Reply To: RMS spot size interpretation
Ethan Keeler
Hi Jurgen,
Just to clarify, the Merit Function as you've have set is giving you the extent of the transverse ray aberration for X and Y simultaneously, and in practive will typically represent the worst offender (larger aberration in X or in Y). In order to see a computation of the actual RMS spot radius, you should set the weight of X and Y to 0 in the Merit Function Wizzard:
You can find more information on what is being calculated here: Optimization Function Criteria.
Thanks,
Ethan
