Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Memory Management Alert for Implicit Analysis in LS-DYNA After Version R10 › Reply To: Memory Management Alert for Implicit Analysis in LS-DYNA After Version R10
igandiko
Please set the memory using the suggested values in the alert. For example, if the mes0000 file shows below alert, try "memory=200m memory2=200m" in the ls-dyna command (for MPP solvers) or just "memory=200m" (for SMP solvers).
A sample SMP command is: /path/ls-dyna i= input.k memory=200m
     ==            IMPLICIT USAGE ALERT            ==
     == Memory Management for Implicit has changed ==
     == after R10.  Please use:                    ==
     ==       memory=   122M memory2=   122M       ==
