Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › compression test of scaffold or lattice structure › Reply To: compression test of scaffold or lattice structure
REZA AHMADI
thank you, which type of stress should i consider to compare with stress strain results, i mean middle principal or maximum principal?in contour i have also positive and negative stress which means tensile and compression
