Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Aqwa – Field points definition › Reply To: Aqwa – Field points definition
November 11, 2024 at 12:31 pm
The problem with changing the colour scale is a known issue - please try creating an environment variable ANS_USE_OPENGL_LEGEND_EDIT with the value of 1, restart Workbench, and try again.
For exporting: in Release 2024 R2, once the Pressures and Motions result has been evaluated, you should find an 'Export to CSV File...' option in the Details panel, which you can use to export all of the Wave Surface Elevation data into a text output file.
I hope this helps.
Mike
