Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Creep Strain Energy Density User Defined Results › Reply To: Creep Strain Energy Density User Defined Results
Hey,
From what i can see the NLCRWK is a valid expression to get creep strain energy density, which is also equivalent to the APDL command result item using PLESOL. However i was not able to find any expression for SENDCREEP. The SENDCREEP is an APDL command which is issued with PLESOL. So the result should match when you issue it using APDL postprocessing commands instead of user defined results.
For the second case, can you check if you have the large deflection set to ON in the analysis settings and a proper creep model defined in the engineering material.
Mohan Urs
