Ansys Learning Forum Forums Discuss Simulation Fluids Cannot modify size field after volume mesh generation in FM Reply To: Cannot modify size field after volume mesh generation in FM
Keyur Kanade
Once size field is calculated, you can not change size functions. To change size functions, you can deleted computed size field by using 'Delete' option in the same panel you have shown above.
You can connect 2 meshes if face mesh on both faces at the interface are exactly same. You will need to use Boundary → Merge nodes option for that. If they are not exactly same then please proceed with non conformal mesh.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
