Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Need help with understanding meshing procedures › Reply To: Need help with understanding meshing procedures
viliusv
Why is that so? After all, I will later update the model by including skin to which I will apply a real pressure distribution obtained from cfd simulation.
I see your point of using surface geometry given the small thickness dimensions but I do not believe it is appropriate for my configuration. I'd much rather like to ask if I can create mesh individually by suppresing bodies that are not being meshed in the moment and then press share topology to ensure that the different meshes get automatically connected together?
