Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Rotation velocity in static structural › Reply To: Rotation velocity in static structural
peteroznewman
Change the Revolute joint to a Fixed Joint.  Change the Frictionless Contact to Bonded Contact. Then the Wheel cannot rotate. Then the Inertial load of Rotational Velocity should give a tiny positive radial directional deformation.
