Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Rotation velocity in static structural › Reply To: Rotation velocity in static structural
November 9, 2024 at 6:01 pm
javat33489
Sir yes, I made the shaft fixed and rotate the wheel on it either by rotation speed or torque.
I made the shaft fixed because it is simpler and the solution is faster than the shaft rotating inside the engine and also rotating the wheel. By rotating the wheel on the shaft I simulate rotation to simulate the transfer of load to the housing of the conditional engine and then to the bolts that hold it.
I understand sir, the application of rotation speed is the best option for static analysis.
