Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Rotation velocity in static structural › Reply To: Rotation velocity in static structural
javat33489
The question is as follows.
I have a motor with a rotation speed of 1500 RPM and a torque of 95 Nm.
I tried to use the torque, but then my model falls apart as I described above, then I used the rotation speed, everything works well.
Did I do everything correctly? Can I replace it?
