Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Rotation velocity in static structural › Reply To: Rotation velocity in static structural
November 9, 2024 at 1:40 pm
Sir, I set the rotation on the wheel, I set the contact between the wheel and the shaft without friction, and so that the wheel does not fly into space, I made a joint between the wheel and the shaft to rotate. Is this wrong? I need to understand how the shaft will behave when the wheel rotates on it
