Ansys Learning Forum Forums Discuss Simulation Electronics IcePak Monitor Returning NaN Value Reply To: IcePak Monitor Returning NaN Value
Chunhui Zhang
Please check the object priority of MOSFET and PCB. If the surface monitor is assigned on the face of object with lower priority, there won't be results as the mesh will belong to the object with higher priority in overlapped region. Please use mesh viewer to check the mesh on the face with surface monitor assignment. If this is the issue, please make the MOSFET priority higher than that of PCB. Thanks.
