Ansys Learning Forum Forums Discuss Simulation Electronics IcePak Monitor Returning NaN Value Reply To: IcePak Monitor Returning NaN Value
Iceman
Is the MOSFET modeled as network? If so, the monitor might have been put inside the network object due to numerical rounding error. Since Solve Inside is unchecked for network objects, there won't value for monitor. Please shift the monitor point slightly downward, then you should see result. Thanks.
