Ansys Learning Forum Forums Discuss Simulation Electronics Assigning current to Multiple Coils? Reply To: Assigning current to Multiple Coils?
Ivonne Marti
Hi Eric,
You should use Transient or Eddy current solver, depending of your application. If I understand well, you have 3 windings corrected in parallel. In Maxwell, each winding can contain one or more wires. When you setup the Winding by default they are connected in series but in the low part of the window you can indicate if they are in parallel. In this case the excitation is specified in Maxwell.
Another option is to create the different windings in Maxwell, but use the External circuit to connect them.
Ivonne
