Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Aqwa – Field points definition › Reply To: Aqwa – Field points definition
Shuangxing Du
If you need the frequency domain wave elevations at specified points on the mean water surface after running the Hydrodynamic Diffraction analysis, it would be better to run a post processor, i.e. AqwaFlow (see AqwaFlow Manual).
