Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent and Rocky coupling question › Reply To: Fluent and Rocky coupling question
satri
I see in coupling limitation that multifluid VOF model is not supported in rocky. does it mean that rocky does not support more than two fluid model in VOF? or it does not support two fluid VOF model in 2way coupling too?
When I look at the verification manual I see only three problems outlined which does not have any example of multiphase model coupling for rocky-fluent.
In the tutorials section, tutorial 14 explains about setting up two-way coupling for a fluidized bed and tutorial 16 for mixing tank
are you trying to say that to achieve the above problem I should follow tutorial 14 or 16 and forget about VOF? Please let me know
