Ansys Learning Forum Forums Discuss Simulation General Mechanical How to set the relevant boundary conditions? Reply To: How to set the relevant boundary conditions?
M210098
Sorry for the inconveinance again. If I only apply compression-only support (for frictionless contact), bearing load (-5000 in y direction) and cylindrical support (fix radial), I would end up arriving at the answer of only 0.2 mm instead. I had tried applying frictionless support instead but that resulted in a solver pivot error. May I clarify this with you again? Thank you.Â
