Ansys Learning Forum Forums Discuss Simulation Electronics Simulation of Cascaded Resistors and Voltage Drops Reply To: Simulation of Cascaded Resistors and Voltage Drops
Mrinmoy Bharadwaj
Kindly correct the set-up for correct results.
1. Your voltage source must be connected between VCC and GND (not NetR1_2). Both voltage and current source should have the same reference net.
2. Select the "negative" for the voltage source under "Node to ground".
