Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › How to get the position of selected nodes in apdl using vget command? › Reply To: How to get the position of selected nodes in apdl using vget command?
Mehdi Baghaee
Just to say that it does not work. I dont know why it returns the location of all nodes instead of the selected ones.
You could check it through my following codes which returns a 484*1 array instead of 18*1 array.
/BATCH
/input,menust,tmp,”
WPSTYLE,,,,,,,,0
/NOPR
KEYW,PR_SET,1
KEYW,PR_STRUC,1
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
/GO
/PREP7
ET,1,SOLID185
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,1e9
MPDATA,PRXY,1,,.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,6700
BLOCK,0,10,0,10,0,1,
FLST,5,8,4,ORDE,2
FITEM,5,1
FITEM,5,-8
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
MSHAPE,0,3D
MSHKEY,1
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CHKMSH,’VOLU’
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
WPSTYLE,,,,,,,,0
FLST,2,44,1,ORDE,12
FITEM,2,1
FITEM,2,-11
FITEM,2,122
FITEM,2,143
FITEM,2,153
FITEM,2,-161
FITEM,2,243
FITEM,2,-244
FITEM,2,267
FITEM,2,-268
FITEM,2,287
FITEM,2,-304
/GO
D,P51X,ALL, , , , , , , , , ,
ANTYPE,4
TRNOPT,FULL
LUMPM,0
ASEL,S,AREA,,6
APLOT,
NSLA, S, ALL
*VGET, NAPOSX, NODE,  ALL, LOC,  X
FINISH
Any suggestion?
