Ansys Learning Forum Forums Installation and Licensing Ansys Products How to get the position of selected nodes in apdl using vget command? Reply To: How to get the position of selected nodes in apdl using vget command?
Harshvardhan
The  APDL command *VGET is executed on the previously selected entities. So if you have selected a group of nodes, and you need location of any one node, you will first need to resect that node so that only that node is selected and then run the *VGET command.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
