Ansys Learning Forum Forums Discuss Simulation General Mechanical How to set the relevant boundary conditions? Reply To: How to set the relevant boundary conditions?
ErKo
Hi
’The steel bracket below has rigid shafts (purple) through holes A and B that fit snugly, where there
is no clearance, but the bracket can slide or rotate with the rigid shafts (cylindrical support – fix radial). Another shaft goes through
hole C (brown) and exerts a total of 10,000 N in the negative y-direction (remote force or like it says bearing load). Only the green bracket
will be analyzed in this simulation.'
All the best
Erik
