Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › AEDT 2024 R2 HFSS Stuck During Parametric Analysis › Reply To: AEDT 2024 R2 HFSS Stuck During Parametric Analysis
AlexHFSS
Hi Aymen,
Thank you for the response. I did a test simulation using the GUI desktop with an HFSS example that contains a parametric analysis.  The parametric analysis got stuck while running the relatively simple HFSS example.
Your links did not work.
Thank you.
