Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non-Convex Cells in ANSYS Forte › Reply To: Non-Convex Cells in ANSYS Forte
Usman
Could you please recommend a value for the central points? The sector angle is 360/7 degrees. The bore and stroke sizes are 11.5cm and 12.5cm. Also, can I import a sector mesh from Solidworks? As, it is easy to create a geometry there. I would mesh it in the forte. I tried importing STL files from Solidworks, but this does not allow me to do name selections. I tried to provide name selection in Forte but I could not find any option to do so.
Your suggestions will be highly appreciated.
Many thanks!
