Ansys Learning Forum Forums Discuss Simulation Materials ACP PRE problem Reply To: ACP PRE problem
Govindan Nagappan
Rosettes are used to define the fiber direction ( X direction for material)
Oriented selected set  is used to define the normal direction (material Z direction).
Regarding the first message in ACP: You have defined oriented selection set on a surface, But the point selected to define the normal direction is not on the surface. If you have disconnected surface mesh, consider defining separate OSS for each surface
Second error message in ACP also refers to sae issue - disconnected surface mesh. You can use separate oss and also if needed, create separate solid models
In ACP make sure you have the correct unit system. Check the size of the solid model and make sure it is correct. Make sure the material properties are defined correctly in the selected unit system
