Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Problem using MATLAB with Lumerical 2024R2 › Reply To: Problem using MATLAB with Lumerical 2024R2
scavallini
Yes, indeed, we are running both versions on the same Linux machine. I get a license error, and usually, after I select the correct license server then, it works, but sometimes it doesn’t. It is a bit random when it works and when it does not. But in the past I have been able to run both version on the same machine at the same time.
