Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Not wanted imprints when exporting from SpaceClaim to Mechanical › Reply To: Not wanted imprints when exporting from SpaceClaim to Mechanical
erik.kostson
Hi
Imprints are generated via the shared topology – normally with these bolts you (very simple) show, we can sweep – try using multizone (leave default set.) on all the bolts as that should also do it.
All the best
Erik
