Ansys Learning Forum Forums Discuss Simulation Fluids CFD simulations with moving mesh on cluster (UDF execution and parallelization) Reply To: CFD simulations with moving mesh on cluster (UDF execution and parallelization)
Did you compile the code on the cluster and check it was hooked correctly. Changing OS requires the library to be recompiled, and depending on the model and paths settings Fluent can save the absolute rather than local path in some panels.
