Ansys Learning Forum Forums Discuss Simulation General Mechanical I want to rotate the FSW tool, but It works strange. Reply To: I want to rotate the FSW tool, but It works strange.
kangjs1420
Thank you for your response.
I've reviewed the example, but it's a pinless FSW form of the butt joint.
The FSW process type I want is a tool with pin, which is a thermo-mechanical analysis of welding for lap joint.
When I activated the large deflection option, there was a problem that the substract element of the location where the tool dug in was over-deformed and did not converge.
