Ansys Learning Forum Forums Installation and Licensing Ansys Products The Ansys Rocky2024 external module is not working properly Reply To: The Ansys Rocky2024 external module is not working properly
Lucas Bertollo Baggio
You should make use of the 2024 R1 modules if you are using Rocky 2024 R1. Could you please check your versions?
