Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Balancing FOMs in Inverse-Designed SWG-Based 2×2 3-dB Power Splitter › Reply To: Balancing FOMs in Inverse-Designed SWG-Based 2×2 3-dB Power Splitter
partha.nakti
Thank you for your reply. However, the configuration shown in the screenshot I provided in my last message isn’t working. As you mentioned, "the actual FOM is only one scalar quantity." Does this mean that in the part
"target_T_fwd = lambda wl: 0.5 * np.ones(wl.size)"
0.5 cannot be used here, and it must always be a single integer? Could you please elaborate on this?
Thank you.
