Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Icepak Mesh Region Creation › Reply To: Icepak Mesh Region Creation
November 5, 2024 at 4:40 pm
Yannis
Hi Paul,
Which AEDT Icepak version are you using? The SubRegion window is not available in older versions (I believe it was introduced in 24R1). When you assign a Mesh region, it creates a Non-model Box around the object. The SubRegion window allows the user to easiy resize the Non-model Box to create padding. In older versions, you need to resize the Non-model Box manually (double click on CreateBox in model tree and modify the Position and X,Y,Z size):
Yannis
