MangeshANSYS
Yes ideally the pre / post processing should happen on machines with workstation class graphics cards with newer graphics driver versions.
how are you accessing X on the cluster? interactively or through some remote display / X forwarding ?
woes it work if you do not set the LIBGL variables and only set th eLD LIBRARY  PATH and start workbench with oglmesa flag
