Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Assistance Needed for Wavelength Adjustment in Optical Ring Modulator Simulation › Reply To: Assistance Needed for Wavelength Adjustment in Optical Ring Modulator Simulation
Guilin Sun
Hi Abhishek,
Optical_Ring_Modulator.icp  is a Lumerical INTERCONNECT file. In its layout mode, you can click the cwl source tab, and modify its wavelength as desired. You can modify the paprameters for all other elements in the layout mode.
