Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Balancing FOMs in Inverse-Designed SWG-Based 2×2 3-dB Power Splitter › Reply To: Balancing FOMs in Inverse-Designed SWG-Based 2×2 3-dB Power Splitter
partha.nakti
Hi Guilin,
Thank you so much for your reply. For a 3dB splitter, the fom_bar and fom_cross portions of the code would be similar, and I would assign a weight of 0.5 to each. Is this what you're suggesting? Please refer to the attached picture for clarification.
Thank you.
