Ansys Learning Forum Forums Discuss Simulation Fluids Correct CFX Pre Setup to avoid isolated fluid regions Reply To: Correct CFX Pre Setup to avoid isolated fluid regions
qnp5rg
Hi mark,
Thank you so much, this is incredibly helpful! A few follow up questions. First, by do not mesh the mussel do you mean the "solid" geometry or the internal volume or both? Second, if I chose the third option I am not sure how one is to mesh only certain faces (the inlet/outlets as you say)?Â
