Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Help! problem about the plane in CFD post › Reply To: Help! problem about the plane in CFD post
Or top and bottom! The mesh is OK, but I suspect the resolution and cell density could become a problem. You may also want to adjust the inflation mesh to keep an aspect ratio of around 1 given the surface tension forces on the droplet and particles. This is not going to be a fast simulation.
