Ansys Learning Forum Forums Discuss Simulation Fluids Correct CFX Pre Setup to avoid isolated fluid regions Reply To: Correct CFX Pre Setup to avoid isolated fluid regions
qnp5rg
Hi Mark,
I am hoping to create a simulation where the interior volume takes in water from the exterior volume of water which will have a tracer added to it and then the interior volume will pump out water into the exterior volume, creating mixing and difference in tracer concentrations along a vertical gradient. Is there a way for me to create two separate meshes for the two fluid volumes and connect them into a single simulation?
