Ansys Learning Forum Forums Installation and Licensing Ansys Products Harmonic Response Analysis. An error occurred while processing the imported data Reply To: Harmonic Response Analysis. An error occurred while processing the imported data
Pedram Samadian
Hi Ashish,
The message points to an issue with how forces are defined or applied in the harmonic response analysis, and I see you have imported the load data into Mechanical. My first guess is there might be an formatting issue within the imported file. Please ensure the file is in a format compatible with Ansys Mechanical. You can find useful information about the data impot into Mechanical in the following link: 5.15.5.2. Importing Data from Mechanical
There might be a few common reasons for this problem in Ansys Mechanical:
- Inconsistent Units or Magnitudes in Force Data: Check the units of the imported data and ensure they match the units in your analysis setup. If force magnitudes or units are inconsistent, it may cause issues in processing.
- Incorrect Load Transfer Option: There might be a conflict with the load transfer option used in the setup. In harmonic response analysis, force-based loads should be correctly defined and applied at each frequency step. Make sure the load transfer method matches the load application type (like point loads, surface pressures, etc.).
- Mesh and Contact Definitions: If the force is applied across a contact interface, verify the contact definitions and mesh refinement at the interface. Problems in contact regions or poor mesh quality can sometimes lead to load application errors.
- Frequency Range or Load Step Issues: Ensure that the frequency range or steps specified are within the valid range of the harmonic response setup. Also, check that the applied force frequencies match those of the analysis.
I hope this information helps you to resolve the issue.
Thanks,
Pedram
