Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to apply Compression-only Support? › Reply To: How to apply Compression-only Support?
November 4, 2024 at 11:10 am
Harshvardhan
To apply frictional contact, you will need 2 bodies that will come in contact. Compression only support can be applied with only one body.
In this case, you don't need to apply frictionless contact if you are applying compression only support.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
